| Maxim |
21.08.2008 - 07:31
![]() Участник Группа: Пользователи Сообщений: 243 |
Вот решил узнать мнение знающего народа, и неспеша выбрать оптимальный вариант.
На этом этапе цена не учитывается. Kore Durox Disc Wheelset Disc Compatibility: new all-in-one disc • Bearing: new adj. sealed cartridge • Axle: Style 6mm QR / front 6mm QR / rear • Finish: shot peen black • Logo: Laser • Rim Material: 6066 welded seam • Finish: shot peen black • CNC: sidewall NA • Eyelet: alloy insert • Valve: p/v tubeless • Finish: / logo black/sticker • Spoke: Brand / Material KORE / Sandvik • Diameter: 14g (2.0) 14g (2.0) • Cross: 2X • SKewer: Finish / logo black • Nipple: Material brass • Extras: center lock & 6-bolt adapter-KORE "chastity belt" rim tape • UST: Tubeless wheelset 818g Front, 1119g Rear. ![]() Mavic Crossride Disc Rims: • Colour: black anodized • Disc brake specific profile: no braking surface • Drilling: traditional • Eyelet: H2 technology • Internal width: 19 mm c • Joint: pinned • Material: 6106 Aluminum • Valve hole diameter: 8.5 mm Spokes: • Colour: black • Count: 24 front and rear • Lacing: front and rear crossed 2 • Material: stainless steel • Nipples: brass, self lock concept • Shape: straight pull, bladed Hubs: • Bearings: QRM • Colour: black • Free wheel mechanism: FTS-X, steel • Front and rear axle material: steel • Front and rear bodies: aluminum • Front axle size: 9 x 100 • Rear axle size: 9 x 135 Compatibility: • Disc brakes: International Standard, Center-Lock • ETRTO size: 559x19c • M10 (Shimano, Sram) • Recommended tyre sizes: 1.5 to 2.3 • Tyre: clincher Supplied with: Rim tape: • Traditional aluminum quick releases • User guide and warranty card • Valve reducer • Weight of pair: 1920 grams • Front wheel: 885 grams • Rear wheel: 1035 grams ![]() Shimano XT Wheel XC M775 Сообщение отредактировал Maxim - 21.08.2008 - 07:32 -------------------- The life won't wait......
Maxim выбор колёс Mtb. 21.08.2008 - 07:31
}I{yK ХТ.
но они дороже чем первые две пары, если цена ... 21.08.2008 - 07:37
Maks Вот они крассавцы!!!!
Shimano XT ... 21.08.2008 - 08:46
кирюша http://www.velosprint.kiev.ua/pictures/rit...disc_... 21.08.2008 - 08:55
serioga Maxim, Mavic Crossride Disc, я доволен полностью с... 21.08.2008 - 08:56
Maxim
Maxim, Mavic Crossride Disc, я доволен полностью ... 26.08.2008 - 17:28
Shimano XT... 26.08.2008 - 18:57
Maxim
те что ты написал - для All Mountain..они под 20м... 26.08.2008 - 19:31
это Макс (HAIBIKE) написал, а не я
:) да,я поня... 26.08.2008 - 22:10
Maks pill,
а что если поменять ротор под сентер лок а ... 26.08.2008 - 22:38
кирюша http://bikeshop.com.ua/product_info.php?products_i... 27.08.2008 - 09:00
ejik колеса должны быть или мавик или дт свис, я на сво... 27.08.2008 - 09:26
pill Maks,
я писал об этом выше...
в принципе должно р... 27.08.2008 - 09:49
Maxim Думаю что привязка к роторам шимано не большой мин... 27.08.2008 - 11:46
pill даже в диаметре роторов есть разногласия...есть ст... 27.08.2008 - 12:42
Maxim Насчёт роторов согласен но на 160 и 180 почти все ... 27.08.2008 - 14:56
есть какая проблема если я на авиды поставлю рото... 27.08.2008 - 15:12
Maxim то есть как я понимаю переклюк могу оставить но ма... 27.08.2008 - 16:07
я слышал что в версиях Shadow улучшена стабильнос... 27.08.2008 - 17:30
ejik pill,
срам манетки работают со срам переклюками, ... 28.08.2008 - 00:19
pill ejik,
тем лучше для конечного пользователя..
Мне ... 28.08.2008 - 09:52
ejik pill,
одинаковое все)) есть разница в метале сами... 28.08.2008 - 10:17
подробнее тут - http://velosvit.com.ua/modules.... 28.08.2008 - 13:46
ejik цепи и касеты срам быстрее изнашиваются, с совмест... 28.08.2008 - 18:38
Maxim
цепи и касеты срам быстрее изнашиваются, с совмес... 28.08.2008 - 18:49
Rois Теме уже 3-ий год, за это время опыта у всех стало... 30.03.2011 - 21:48
Demon Мне кажется самый лучший способ собрать колеса те ... 30.03.2011 - 22:03
Мне кажется самый лучший способ собрать колеса те... 30.03.2011 - 22:09
Demon На счет того что тебе не "нравятся" гром... 30.03.2011 - 22:21
OTARvashka чудные колеса! 30.03.2011 - 23:54
Maxim С момента создания темы успел поменять велосипед. ... 31.03.2011 - 14:21
}I{yK самый оптимал
хоп про, фтулки под 6 болтов (на пр... 31.03.2011 - 15:04
OTARvashka
втулки новатек дешевле тоже на промах в украине ... 3.04.2011 - 16:15
RedCap После консультации с Максом и по настоянию Брата А... 31.03.2011 - 15:53
vova13 втулки Formula на промах, дешего, легко обслуживат... 31.03.2011 - 15:56
Переклюк Покрышкин Ребят а есть какойто метод для тестирования втулок... 3.04.2011 - 14:43
не понимаю почему накат такой никакой.....сдается... 3.04.2011 - 18:03
Бэтмэн Дело не во втулках. Хорошая техника спуска у тех к... 3.04.2011 - 15:28
Переклюк Покрышкин ага мы все технари с нереально крутым стажем)) осо... 3.04.2011 - 16:07
Demon Переклюк Покрышкин,
да ты легок -это раз!а во... 3.04.2011 - 19:46
Переклюк Покрышкин
Переклюк Покрышкин,
да ты легок -это раз!а в... 3.04.2011 - 21:22
2fast
сколько проехали не смогу сказать,ехала девушка н... 3.04.2011 - 21:43
trek Eu am Pro-Lite Allein. Foarte usoare F: 742 g / R:... 3.04.2011 - 20:51
Laur-Balaur
Стаж у меня больше 2,5 лет
если все на одном и т... 3.04.2011 - 21:46
Переклюк Покрышкин
если все на одном и том же, то тогда у тебя 100% ... 3.04.2011 - 22:03
Laur-Balaur особые - это не то определение, но лучше искать ша... 3.04.2011 - 22:14
Переклюк Покрышкин
особые - это не то определение, но лучше искать ш... 3.04.2011 - 22:34
Rois Переклюк Покрышкин, у меня было без шумов. Если см... 3.04.2011 - 22:41
Переклюк Покрышкин
Переклюк Покрышкин, у меня было без шумов. Если с... 3.04.2011 - 23:21
Rois а теперь будет самое интересное, если у того, с ке... 4.04.2011 - 00:21
Переклюк Покрышкин
а теперь будет самое интересное, если у того, с к... 4.04.2011 - 08:38
Demon Переклюк Покрышкин, при таком состоянии конусов ты... 4.04.2011 - 07:09
Demon возможно все таки царан!))))раз катаешь по асф... 4.04.2011 - 08:49
Переклюк Покрышкин
возможно все таки царан!))))раз катаешь по ас... 4.04.2011 - 10:47
Demon Так какого ты тогда удивляешься тому что злая и бо... 4.04.2011 - 11:01
Переклюк Покрышкин да потому что мне кажется что не могут 0,3 дюйма р... 4.04.2011 - 11:22
Zёga
да потому что мне кажется что не могут 0,3 дюйма ... 4.04.2011 - 11:34
Переклюк Покрышкин
реально ты ни фига не шаришь, возьми переобуй на ... 4.04.2011 - 11:36
Demon Покрышкин,дело не в объеме:)а в зубастости резины.... 4.04.2011 - 11:28
Переклюк Покрышкин хорошо,спасибо Демон! Возможно ты и прав а мож... 4.04.2011 - 11:34
Demon Нужно взглянуть,посмотреть что и как.А тему не ты ... 4.04.2011 - 11:40
Переклюк Покрышкин
А тему не ты открывал,поэтому не тебе закрывать.:... 4.04.2011 - 11:49
Rois Переклюк Покрышкин, говнецом попахивать не будет, ... 4.04.2011 - 13:20
Переклюк Покрышкин
Переклюк Покрышкин, говнецом попахивать не будет,... 4.04.2011 - 13:23
Бэтмэн Давайте по теме. 4.04.2011 - 15:26
2fast а по теме, хотелось бы узнать для какого стиля кат... 4.04.2011 - 15:54
а по теме, хотелось бы узнать для какого стиля ка... 4.04.2011 - 16:45
vova13 Rois,
Если ты определилась со стилем катания, по-... 4.04.2011 - 17:45
Rois vova13, ценовой диапазон 200 евро, новые или б/у к... 4.04.2011 - 18:16
vova13 как раз собираю себе колеса на втулках formula - о... 4.04.2011 - 20:53
zuevjeen Я себе недавно собрал колеса на формуле сзади DC58... 5.04.2011 - 13:14
На счет наката это физика 5 класс
Физику 8 клас... 5.04.2011 - 14:56
gruffy У меня стоят Mavic Crossroc UST. Накат отличный, н... 7.04.2011 - 14:27
vova13 колеса в сборе:
обода:
Mach1 NEO DISK, ... 8.04.2011 - 10:50
Demon Ну так они предназначены для оффа,если в них 20 сп... 8.04.2011 - 14:03
pill я за мавики кросс -*** чтото там на что денег хват... 8.04.2011 - 18:38
ДТ. - ок колёса только обода както легко мнутся )... 8.04.2011 - 18:49
dimon а по мне так 5 спиц рулет и 142 стиль смотрится бо... 8.04.2011 - 21:17
Demon }I{yK,
у всех плоховидящих они мнутся одинаково л... 8.04.2011 - 21:49
vova13
и при этом совершенно не важно какие обода стоят. 9.04.2011 - 07:14
и при этом совершенно не важно какие обода стоят.... 9.04.2011 - 11:35
dimon плохо ездящие,плохо видящие,плохо думающие это все... 9.04.2011 - 12:28![]() ![]() |
Текстовая версия | Сейчас: 12.09.2026 - 05:43 |
